HomeVisit Homepagehttp://www.theshulers.com/mr2/0-60_a...Mile_Times.txtVisit Homepagehttp://www.mrtwo.net/mr2modproject/s...lantflush1.htmhttp://www.theshulers.com/mr2/0-60_a...Mile_Times.txtToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
drained, flush, coolant, called, water, times, coming, block, finally, radiator, 10-12, bubbles, small, bled, methods, differnt, failed, basically, temp, good, stays, http://img.photobucket.com/albums/v313/cyfi/car/56502f4b.jpg, http://img.photobucket.com/albums/v313/cyfi/car/b102ccab.jpg, http://img.photobucket.com/albums/v313/cyfi/car/48f2f07d.jpg, fine, runs, adding, fluid, entire, stat, engine, strait, inlets, full, decided, chunks, removed, redrained, paint, filling, fresh, bleeding, today, brown, gave, sw20, longest
- Did my first sw20 coolant flush today, it was a paint, took me the whole day. After i drained the radiator i saw chunks of ****, and decided i should probably do a full flush. So first i drained the radiator, then i removed one of the water inlets, the one near the t stat, and drained out some of the engine block, then i ran strait water over and over and redrained like, 5-6 times, yet it was still coming out brown. Finally i gave up and just put fresh coolant in. Filling took a little while,
