AI智能索引来源:http://www.mr2.com/forums/threads/76106-ignition-problems
ignition problems
start, dash, turn, light, multiple, times, wires, starting, shitty, alarm, system, problem, everytime, switch, fuse, find, checked, found, starter, problems, relay, battery, back, turned, luck, part, today, lights, ignition
    Everytime i go to start my car i had to turn the key back and forth multiple times for it to start, when i put the key in a turn it to the right the only dash light that comes on is my battery light and it wont even turn over. Once the key turned multiple times all the dash lights would come on and it would start right away. Today i tried to start it and had no luck. i took off the under part of the dash and found that whoever did the alarm system before me did a shitty job and there are wires
