Homehttp://mr2.zhinengdaohang.com/com/forums/threads/89...en4+mega+buildhttp://mr2.zhinengdaohang.com/com/forums/mk-2-mr2-s...tml#post246485http://mr2.zhinengdaohang.com/com/forums/threads/89...en4+mega+buildhttp://mr2.zhinengdaohang.com/com/forums/threads/89...en4+mega+buildhttp://mr2.zhinengdaohang.com/com/forums/threads/89...en4+mega+buildToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
start, timing, engine, coil, work, distributor, spark, couple, water, teeth, yesterday, thing, plugs, problem, time, ignitor, signal, send, wires, turn, fuel, power, started, roughly, tranny, hooked, grounds, back, portway, weeks, replaced, clutch, pump, belt, tested, clockwise, seconds, turned, fuzes, igniter, days
- ok so a few weeks ago i replaced the clutch timing belt water pump and water portway, i took the engine and tranny out to do all the work. i now have the engine in and it wont start. i have everything hooked back up all the grounds and everything. i tested for bad coil igniter distributor fuzes all are ok. a couple days ago i had spark and the engine would start roughly (with the distributor turned all the way clockwise) for about 5-8 seconds and die. that let me know timing was off a couple
