HomeVisit Homepagewww.columbusstreetracing.netSteel braided clutch lineExeedy Stage3 organic clutch (installed)Bronze shifter bushings and Brass shifter base bushings (installed)Custom fabricated air intake (installed)All new OEM ignition components (installed)KYB AGX 4 way adjustable dampers (installed)Eibach Pro-Kit progressive rate SpringsKYB upper pillow-ball mounts (installed)KORacing EGR block-off platesCNC Machined 2.6'' Throttle Body Inlet (installed)RC engineering 440cc injectorsBored out fuel rail with Dual-Feed modificationNew CT26 Rebuilt turbocharger (trying to sell for ATS Racing CT27)Finishline Ceramic Coated exhaust manifoldHKS hiper Cat-Back exhaustHKS hiper B-pipeHKS FCD (fuel cut defenser)93 wheels/tires (installed)Powerslot front/rear rotorsTWOSRUS manual boost controllerNew Black Leather Center console (mine was cracked)JE 8.5:1 Forged PistonsGreddy type OS Front strut barGreddy type OS Rear strut barVMAX Anti-Torque Bar (connects transmission to subframe)SSAutochrome Intercooler & 2.5" Upper intercooler pipe kitMomo Race-Air Leather shift knobDownpipe Support Bracket (keeps downpipes from cracking due to engine movement)Aussie 3" downpipe, HPC coatedTRD Short Shift Lever (installed)ARC Induction Box (against drivers side vent)www.DJKiddquikk.comwww.myspace.com/chrisschnellVisit Homepagewww.DJKiddquikk.comwww.myspace.com/chrisschnellVisit Homepagewww.DJKiddquikk.comwww.myspace.com/chrisschnellhttp://www.theshulers.com/mr2/0-60_a...Mile_Times.txtVisit Homepagewww.DJKiddquikk.comwww.myspace.com/chrisschnellVisit Homepagehttp://www.mr2board.com/forums/turbo...-ebay-kit.htmlVisit Homepagewww.DJKiddquikk.comwww.myspace.com/chrisschnellVisit Homepagehttp://www.mr2board.com/forums/turbo...yeah-came.htmlwww.DJKiddquikk.comwww.myspace.com/chrisschnellVisit Homepagewww.DJKiddquikk.comwww.myspace.com/chrisschnellhttp://columbussr.proboards22.com/in...5402568&page=1Visit Homepagewww.DJKiddquikk.comwww.myspace.com/chrisschnellVisit Homepagewww.DJKiddquikk.comwww.myspace.com/chrisschnellVisit Homepagewww.DJKiddquikk.comwww.myspace.com/chrisschnellToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
fuel, installed, turbo, t3/t4, injectors, inlet, shop, stage, components, http://img455.imageshack.us/img455/7704/chrisengine5kz.jpg, engineering, pictures, bushings, pump, side, timing, motor, downpipe, intercooler, shifter, http://img486.imageshack.us/img486/5241/10007518gn.jpg, people, type, parts, manifold, reason, 3.00, trim, 2.00, degrees, outlet, tuning, listed, compressor, float, turbine, coated, st165, blow, valve, hiper, exhaust, spring, rail, 38mm, wastegate, bearings, compensate, money, build
- Below is just a composit of posts made on my own site (www.columbusstreetracing.net) that show my cars progress through the months!!!
I
