5S-FE MK2 Non-Turbo Engine Fluctuating Idle... Water Temperature Sensor?
5S-FE MK2 Non-Turbo Engine, sensor, water, idle, temperature, opening, fluctuating, engine, check, driving, readings, replacing, causing, warm, happening, stop, cold, summary, failing, plan, contacts, valve, control, cover, vent, speed, surges, 1991, automatic, surging, found, stopped, issues, tested, work, fine, back, problem, corrosion, sanded, giving, erroneous, times, correct, gave
1991 MR2 Automatic
Surging / fluctuating idle while stopped and while driving.
I found that when it surges the Idle Speed Control valve is opening, so when I cover that vent I have no issues.
I tested the Water Temperature Sensor and it was giving me erroneous readings at times and sometimes gave me the correct readings. I sanded the contacts for corrosion and it seemed to work fine for a while.
Now the problem is back again, I plan on replacing the sensor but I can
