AI智能索引来源:http://www.mr2.com/forums/threads/79698-Replaced-Alternator-and-Still-NOT-charging%21%21
Replaced Alternator and Still NOT charging!!
alternator, not charging, replaced, toyota mr2, engine, fuse, light, battery, month, starter, circuit, on/in, drawing, completely, turned, connections, fuses, current, check, finding, water, finally, started, open, fitting, admit, pulled, raining, removed, back, doubt, frunk, dome, drove, jumped, minutes, driving, dropping, level, noticed, sitting, installation, charging, fellas, turn, died, tachometer, dieing, alive, problem
    Hey fellas I replaced the alternator a month ago and the starter died on me while trying to turn on the car after the installation. So after sitting for another month I got the starter in and jumped the car and drove it for 10 minutes. While I was driving I noticed the battery level dropping really low and the tachometer needle began jumping and I got the P/S light. This is indicative of no charge left in the battery. Now the thing is, before I replaced the alternator when the engine was
