AI智能索引来源:http://www.mr2.com/forums/threads/7985-Fuel-System-Primer
Fuel System Primer
stock, pump, injectors, fuel, rail, feed, work, cc/min, larger, supra, system, walbro, modified, good, side, supply, rails, power, lines, return, custom, support, aeromotive, needed, tank, folks, cams, make, boost, pickup, safely, turbo, engine, td06, improved, sized, t3/t4, goals, pumps, pressure, similar, found, line, head, things, aftermarket, hands, regulator, drop, complete
    I can approach this from a fuel system management perspective, but if you were to ask me exactly what whp level requires what, I can only make suggestions. We have written a few tech articles on the subject found here: http://www.wolfkatz.com/articles.php But another good place to look is our MR2 FAQ found here: http://www.wolfkatz.com/MR2FuelFAQ.php The basics work like this: --- When you demand more fuel than the stock injectors can put out (you can raise your base fuel pressure with
