AI智能索引来源:http://www.mr2.com/forums/threads/80852-cooling-problem
3S-GE JDM Non-Turbo Engine cooling problem
3S-GE JDM Non-Turbo Engine, water, problem, yesterday, pump, thermostat, time, temprature, normal, dirty, flushed, pipes, filled, leak, front, rusty, reason, gasket, head, english, pleaseeeeeeeeee, concluded, logical, hose, list, problems, radiator, steam, meters, back, stove, folks, toyota, replaced, stood, idle, minutes, drove, home, trouble, vented, distribution, cooling
    Hi folks I have a big problem with my toyota .. when you go away you need at a time when the temprature is normal, and then get the stove is not hot, and is the temprature meters in a time to the red and you see the steam out of the car, and back too .. water pump was replaced yesterday, inc distribution, thermostat everything, everything is well vented, yesterday he did it as normal, 20 km without any trouble, then he maybe 2 minutes at idle stood still, and I drove home the same problem,
