AI智能索引来源:http://www.mr2.com/forums/threads/81051-Driver-window-stuck-down
Driver window stuck down
window, regulator, door, roll, motor, stuck, tested, condition, teeth, good, issue, frame, back, works, flawlessly, reconnect, forum, hear, position, time, drivers, stick, bought, looked, driver
    My drivers window is stick down and every time I try to roll it up all I hear is the motor, but the window is still stuck at the down position. So I bought a used regulator here on the forum and took out the old one and it looked exactly the same... Both teeth were in good condition, and I tested the motor with the regulator our of the door frame and it works flawlessly. But when I reconnect everything back into the door the window would still not roll up. What could the issue be here?
