AI智能索引来源:http://www.mr2.com/forums/threads/8114-Help-I-got-a-wierd-problem
Help I got a wierd problem.
timing, drove, checked, tach, fine, ignition, wired, system, gotto, makes, heat, soldered, bought, shrinked, made, moves, figure, weather, balls, code, hair, pulling, works, starter, rotors, wires, plugs, hacked, slaving, ground, running, tooth, funny, fixed, mechanical, positive, belt, recently, problem, wierd, weird, problems, studdered, cylinders, switch, compared, find, wiring, power, shuddered
    How come I get all the weird problems? Well here it is. I recently did a timing belt. Got it together drove it around and the car drove funny like it was a tooth off. SO I checked the timing. I
