AI智能索引来源:http://www.mr2.com/forums/threads/83948-What-is-this-part-called
Other What is this part called?
Other What is this part called?,AI智能索引,全网链接索引,智能导航,网页索引
    :confused: There is a rod that runs over the shift forks on top of the transmission bellhousing. Its attached to the shift cables and its the final connection that decides what gear the transmission will be in by rolling over the forks sticking out of the gear housing.. Either way, I had to swap mine to a different trans and bent it. Not too sure if it
