AI智能索引来源:http://www.mr2.com/forums/threads/87181-Alternator-problem-maybe
3S-GTE USDM Turbo Engine Alternator problem maybe?
3S-GTE USDM Turbo Engine, jumper, cables, alternator, remove, back, dies, sputters, start, hook, kind, guys, chirping, started, fine, running, week, mechanic, friend/toyota, coming, sounds, viscinity, general, noise, revving, starts, disconnect, pull, clicked, problem, yesterday, revs, runs, seconds, wait, cable, engine, fall, leaving, idle, longer, time
    So... went to start her up yesterday and no go... Just clicked... So, I pull up my other car and hook up the jumper cables and the two starts right up. I go to remove the jumper cables and as soon as I disconnect the first one the revs fall and the engine sputters and dies. So, I hook the jumper cables back up and start it up, leaving it to idle for longer and revving it a bit. I go back and remove the first jumper cable and wait... it runs ok for about 10 seconds this time then
