AI智能索引来源:http://www.mr2.com/forums/threads/88870-How-to-replace-a-fuel-pump
5S-FE MK2 Non-Turbo Engine How to replace a fuel pump
5S-FE MK2 Non-Turbo Engine, fuel, hose, easier, lines, metal, filter, disconnect, couple, pump, firewall, 10mm, called, piece, black, wired, replacing, unbolted, tray, nuts, time, good, portion, longer, budging, replace, mine, splash, uncomfortable, shields, work, concrete, tools, jackstand, brake, cables, hard, budge, days, bracket, filler, brackets, unscrewed, special
    Im thinking about starting this project. It has not been done since 1991 so its due. I have seen multiple people do theirs on this forum. The only thing is that seeing a picture of an intact fuel tank, and then five seconds later scrolling down to see it disassemble can kind of misrepresent the amount of work and skill it takes to do the job. I know many of the people here have YEARS of experience and lots of tools. I have never removed a fuel pump and have only a couple jacks and a socket
