AI智能索引来源:http://www.mr2.com/forums/threads/89431-Valve-Clearance-Question
3S-GTE JDM 2nd Gen Turbo Engine Valve Clearance Question
3S-GTE JDM 2nd Gen Turbo Engine, shim, clearance, caused, valve, wanted, double, 2.72mm, added, 0.330mm, measured, clearances, 0.305mm, check, width, drastically, turn, times, crankshaft, change, lobe, place, .179mm, upturned, gauge, feeler, 2.78mm, decided, dealer, ahead, knock, show, waiting, question, rubber, heater, hose, inlet, damage, kind, 23979, worry, lobes, removing, wanting, shims, noticed, imperfections, couple
    While waiting on my $75 rubber heater inlet hose to show up at the dealer I decided to go ahead and knock out my valve clearance like I
