AI智能索引来源:http://www.mr2.com/forums/threads/9015-Running-on-3-cylinders%21-Help%21%21%21
Running on 3 cylinders! Help!!!
engine, plugs, problem, replaced, probs, guys, started, cable, prob, tells, mech, kind, drive, ides, stumpedconfused, baby, starting, turkey, cold, recorded, blocked, number, codes, error, time, injecter, spark, began, absolutely, works, leaking, clutch, cylinders, leaks, bushings, motor, long, gaskets, mounted, intermittent, drove, home, garage, cylinder, running, fuel
    @ any and all!!! I was having probs with oil leaks and had all of the bushings and gaskets on the engine replaced. As long as the motor was out I had the clutch replaced as well. So, before this all began I had absolutely no probs with the engine - except that I was leaking oil ;-) All the work
