AI智能索引来源:http://www.mr2.com/forums/threads/90382-AC-question%21
radiator, kicks, high, side, blowing, lower, fans, colder, turning, noise, screeching, worn, question, start, compressor, makes, clutch, pitch, turn, warm, setting, drive, cold,then, cold, idle, changing, weird, guess, temperature, panel, coming, wire, water, problem, relay, control, sensor, frunk, relays, working, check, feels, difference, fuse, notice, driving
    when idling , my ac on full blast would not go cold at all! this was even idling at 5minutes after start up. Then i started driving and 2-4minutes later my ac got cold. Does that mean the fan in the front stopped working? Also, how many sets of fans are in the front of our cars, 2? one for the radiator and one for the ac?
