flywheel, shaft, input, fidanza, trans, shot, sound, bearing, gear, noise, throttle, clutch, mass, there.and, absorb, causing, it?,has, good.im, wondering, vibrations, alot, vibration, stock, shaft.is, it.could, trannies, tranny.im, 75-90, mobile, weight, oil.i, back, feed, apreciate, synthetic, fully, miles, 70,000, untill, yeah, lighter, there.not, problem?the, deccelerate, engine, 4000, chattering, coming, kinda, loud
:confused: ok im new on this forum.But heres the issue.i just put a spec stage 2+ clutch and a fidanza flywheel in a 94 turbo with lsd tranny.got it all together and everything is fine except now when im at about 4000 rpm and let off the throttle and let the engine deccelerate you can here this loud grinding or kinda chattering noise coming from the tranny.when the noise is happening the second i disengage the cluth it goes away,and as soon as i engage the clutch it comes back,or if i step on
