AI智能索引来源:http://www.mr2.com/forums/threads/90848-Gen3-amp-Gen2-Fuel-Pressure-Regulator
Gen3 & Gen2 Fuel Pressure Regulator
regulator, pressure, fuel, fittings, installed, lines, expensive, gauge, aftermarket, adjusting, bonus, desired, level, jimb, http://i87.photobucket.com/albums/k154/benckj/photo0303_zps093b4fb5.jpg, http://i87.photobucket.com/albums/k154/benckj/photo0296_zps6519f3c3.jpg, added, fault, finding, recently, rarely, regulators, problem, fail, strange, punctured, sounds, definetly, gen2, diaphram, caused, failure, stock, replace, gen3, monitor, wanted, simple, heat, blocked, return, line, excessive, adjust
    i was wondering if anyone knows is the fuel pressure regulator is the same on a gen2 as on a gen3?
