Warning: SimpleXMLElement::asXML(E:\phpstudy_pro\zhinengdaohang\sitemaps\sitemap_7.xml.tmp): failed to open stream: Permission denied in E:\phpstudy_pro\zhinengdaohang\dd.php on line 1330
MK1 V6'ers...why? - AI智能索引
AI智能索引来源:http://www.mr2.com/forums/threads/9142-MK1-V6-ers-why
MK1 V6'ers...why?
weight, feel, torque, squirrelly, stock, handling, affected, lastly, rough, answer, guys, people’s, future, questions, repeat, 4agze, motor, don’t, numbers, swapping, you/are, research, v6ers, offensive, running, 10psi, pulls, nicely
    I am not asking this to be offensive but more so for research.... Why did you/are you swapping in the v6 to the MKI? Do you feel that you need more torque? I have a s/c running about 10psi and it pulls nicely, but would more torque be even better. For those of you who run the v6 already how do you like it? Does the car feel squirrelly at all and is the handling affected at all by the weight? Lastly does anyone know the weight of the stock 4a or 4agze motor? Rough numbers will do.
