AI智能索引来源:http://www.mr2.com/forums/threads/91472-need-help-starting-mr2
need help starting mr2
fuel, injector, cold, problem, injectors, hook, switch, timing, light, damn, inject, signal, anoid, idles, motor, frustrate, wrong, sell, causing, change, luck, found, forum, spraying, rail, starts, years, starter, burns, dies, fluid, awhile, 1991, starting, 3sgte, started, sitting, pump, cleaned, pressure, system, changed, harness, ohmed, running, hear, works, diagnostic, pins, short
    So here my problem. I can
