AI智能索引来源:http://www.mr2.com/forums/threads/9170-Need-Pitch-Size-information-ASAP
Need Pitch/Size information ASAP
ssac, header, pitch/size, asap, loose, information, test, drive, ditch, find, land, sends, bolt, size, hole, fucktarded, reason, block, sensor
    SSAC Header The second O2 sensor hole on the header itself. What size is the bolt that goes in there to block it off? For some ****tarded reason SSAC sends them to you loose, but on, so when you go out and test drive your car they fly off and land in a ditch so you can
