AI智能索引来源:http://www.mr2.com/forums/threads/92871-Alternator-help
5S-FE MK2 Non-Turbo Engine Alternator help
alternator, issues, mk2, 5S-FE MK2 Non-Turbo Engine, engine, problem, check, fuse, gonna, hand, sway, exhaust, control, easier, side, sounds, hope, loosen, bolt, member, cruise, tensioner, people, connect, compartment, plug, drop, actual, times, cross
    So I am almost ready to drive my mr2 out on the road when i realized my alternator was bad. I separated the alternator wire and battery in the back fuse box and the alternator was bearly charging the battery with .4 volts that is nothing. Anyways I lifted the car up and my brother told me that it could just be the wire that tells the alternator to charge that is not functioning properly. So i pulled out the plug and i was wondering if anyone knew what the three wires it has are? I am trying to
