AI智能索引来源:http://www.mr2.com/forums/threads/92953-High-Idle-HELP-%28
High Idle...HELP :(
timing, 1200, idle, body, throttle, valve, ideas, hell, 1600, clean, back, hole, vacuum, drops, connected, leak, inlet, cover, smaller, square, happen, shaped, found, degrees, btdc, failed, beautiflly, 1991, 5sfe, smog, idled, advanced, high, screw, figured, adjustment, idles, procedures, prescribed, jumped, e1t1, dirty
    1991 5SFE Took to smog guy car idled at 800 beautiflly.... timing was found to be 8 degrees BTDC, so it failed... I advanced timing (using prescribed procedures/ timing gun/ jumped E1T1 etc.) idles at 1200. Throttle body adjustment screw all the way in...can
