HomeVisit HomepageVisit HomepageVisit HomepageVisit HomepageVisit HomepageVisit HomepageToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
5S-FE MK2 Non-Turbo Engine, wear, idle, good, screw, rebuilds, maxbore.com, turned, completely, 5sfes, performance, expect, deal, price, bored, $125, plain, biss, guessing, idea, high, problem, fast, plate, throttle, 5sfe
- Theres been tons of posts on this lately. This is the only way to fix it. You must start on step one, and follow every step 100%. No skipping.
Step one: check your throttle cable. If its too tight, thats your problem.
Step two: Your throttle body has a flat head idle adjustment screw on top. Sometimes theres a little plate about 10mm in diameter covering it. Remove it and screw the idle screw all the way in (right). That usually wont fix it, but start there. Now warm your car up, remove
