AI智能索引来源:http://www.mr2.com/forums/threads/93522-Intermittent-Dome-Light-Power-Issue-Fixed%21
Intermittent Dome Light Power Issue Fixed!
dome, power, housing, side, connector, light, rivet, electrical, ground, tester, plug, tools, switch, joint, screw, issue, constant, work, back, make, note, hole, front, slightly, test, solution, troubleshoot, testers, quick, solder, issues, pliers, easy, continuity, meter, cover, intermittent, bulbs, screws, simple, solutions, prongs, fingers, jumpers, assembly, door, problem, worked, figure, reconnect
    Hello all, I know there are some other threads on this forum asking about the intermittent/loss of power to the dome light and there is not any posted solutions that I have found. The other day I decided to try to figure it out and I am happy to say I have solved my issue, and hopefully I can help anyone else looking for solutions to similar issues they maybe having. The troubleshoot and fix could be done with simple tools in less than 10 minutes. First I will describe the symptoms I
