AI智能索引来源:http://www.mr2.com/forums/threads/94730-Friction-Stir-Welding
Other Friction Stir Welding
Other, welding, friction, stir, weight, subframe, added, there’s, wire, required, thing, extra, accord, feature, coolest, recently, 2013, sought, toyz, raczing, florida, raton, boca, save, utilized, expect, applications, thin, hear, hand, aluminum, future, weld, mfg’s, hasn’t, catch, type, “old”, issue, driver, article, widespread, usage, metals, pressure, 1991, invented, doesn’t, heat, require
    Friction Stir Welding In the May issue of Car and Driver there is an article about a “old” type of welding that has been used by mfg’s but hasn’t seemed to really catch on in widespread usage. Friction Stir Welding was invented in 1991. FSW doesn’t require heat. It uses pressure and friction only. It can be used to weld 2 different metals (which are usually difficult by hand) and is used recently in the 2013 Accord subframe. The thing that I think is the coolest feature is that no
