AI智能索引来源:http://www.mr2.com/forums/threads/95183-Bought-a-93-NA-Speedometer-doesn-t-work-Need-help%21%21%21%21%21
Bought a 93 NA. Speedometer doesn't work. Need help!!!!!
computer, speedometer, determine, good, wire, capacitors, repair, steps, speed, assume, safe, defective, replacing, intact, speedo, working, cluster, instrument, continuity, speedometers, finally, purple, solid, wiring, printed, bring, place, soldering, electronics, luck, turns, confident, feel, refer, board, circuit, tachometer, capacitor, procedure, similar, volts, online, give, sources, free, link, case, google, download, manual
    Ok so I bought a 93 NA about 3wks ago. The speedometer doesn
