Warning: SimpleXMLElement::asXML(E:\phpstudy_pro\zhinengdaohang\sitemap_index.xml.tmp): failed to open stream: Permission denied in E:\phpstudy_pro\zhinengdaohang\dd.php on line 1256
3S-GTE JDM 3rd Gen Turbo Engine Anyone understand a COR? - AI智能索引
AI智能索引来源:http://www.mr2.com/forums/threads/95557-Anyone-understand-a-COR
3S-GTE JDM 3rd Gen Turbo Engine, continuity, volts, fuel, pump, time, days, wires, harness, drove, follow, wiring, problems, ground, igniter, start, back, wire, times, loop, humid, _-note, point?++, covered, ignition, checked, great, white, residue, ithad, start--, opening, spraying, bottom, hook, checking, weeks, crank, circuit, board, work, properly, grounded, clicking, actual, relay, guide, twobrutal, gave, voltage
    Very lost on the COR! Hello everyone, I have been around for some time trying to get an issue with my MK1.5 sorted out. I am not sure where to diagnose next so I was maybe looking to see if someone could point me in the right direction. Firstly I shipped my car from texas to the northeast, and my car got rained on pretty heavy a few times. One time the ECU itself even got wet while it was plugged in (about 3-4 months ago now). So I dried it off before I started the car and the car drove ok
