full throttle shift (stock ECU)
clutch, ignition, shift, pretty, throttle, limiter, full, turns, setups, switch, works, gears, moment, active, wire, ground, pressed, limit, years, basically, start, noting, setup, kick, 3-5th, hesitation, stock, thinking, lower, 3300rpm, cuts, damn, wanted, make, running, launch, control, ride, fuel, opens, starting, wondering, experience, opposed, shifts, smooth, regular, drive, re-learn, shifting
so i got the full throttle shift setup running, but i think it needs a little bit of tweaking..
basically, what i did was this:
i had a crane cams ignition box lying around in my basement for a few years. i always thought it was blown, so i never bothered with it. on a whim, i tried installing it on the 2, and it wouldn
