AI智能索引来源:http://www.mr2.com/forums/threads/97666-Power-steering-pump-sound-question
Power steering pump sound question
rack, setting, tape, work, valve, control, easily, stretch, steering, stretched, loose, pump, installing, sound, pita, part, ^^^^, changing, question, rings, teflon, portion, properly, fact, matter, turbo, side, leaking, started, recently, mine, hard, ready, install, middle, start, making, electrical, pull, tricky, seal, messing, housing, back, pre-load, teeth, wrap, parts, complicated, feel
    So my rack and pinion has been leaking since i bought my car so i decided to put some lucas power steering fluid with stop leak in it, until i can afford a new rack. At first i had no power steering at all, then i went inside for a bit, came back out while the car was still running and checked the steering again, and now it was working fine. My only concern is now my power steering pump is making a running noise, is this normal? Ive put regular power steering fluid in it before and never
