AI智能索引来源:http://www.mr2.com/forums/threads/97991-AFM-help
sensor, issue, driving, engine, normal, connector, wiring, part, male, prongs, contact, drive, harness, female, plug, plugs, missing, slide, receivers, drives, reason, foot, 3028830287, drove, 23mpg, completely, freeway, greatest, stock, person, 3gste, mileage, check, light, problem, code, months, annoying, deuce, purchased, turn, fine, points, thing, stuck, joints, soldering, start, disappears, cleaned
    I have been having a little annoying issue with my AFM sensor ever since I purchased my deuce about 3 months ago. well the problem is that while driving a check engine light will appear which is code 24 (IAT sensor) but when I turn the car off & on it disappears until I start driving again . I took my AFM sensor a part , cleaned it with electrical contact spray & made sure all the soldering joints , contact points etc were fine which they are. . One thing that stuck out to me was that there is
